7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#432639 07/14/2008 6:15 PM
Can't remove the front brake drums from my '57 3100 truck. I've backed off the self-tighteners, applied some heat but they show no sign of loosening, used PB Blaster. Is there anything else that needs to be released before they will come off. I'm hesistant on hamering too much on them? Thanks
Two 1957 Chevy Step Sides
1988 Fiero Formula
1987 Fiero GT
1984 Fiero Indy
... yes I like Fieros also..
Sorry, I have to ask--did you take the cotter pin, bearing nut and washer off? I would assume so, but you didn't mention it...
Will the drum turn any at all, or are the shoes still rusted on or too tight for it to turn?
R-Bo
1966 GMC 305V6 in the family
Just as R-Bo said, the drums are attached to the hubs and come off with the hubs.
like lonnie and r-bo stated, i did the same thing, hammering, etc, until i just took the drums off with the hub.
and by the way guys, when you do take it off with the hub, how do you get the hub separated from the drum, lets say you want to get the drums turned, how do you separate ?
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Riding in the Passing Lane
It's best to turn the drums on the hub. To remove the drum for replacement some have 3 rivets holding them on. They can be cut, drilled, or ground down. In fact they need to be removed if you run special wheels. They can keep the wheels from seating. Some models use 3 slotted screws holding them on. Some dont have anything holding them on & are just stuck to the drum.
1972 Chevy c10 Cheyenne Super
thanks wrenchbender. now i know how they work.
leonard
