7 members (Gdads51, TUTS 59, Buckeye998, Robert Crandall, Greg_H, 2-Ton, 1 invisible),
362
Mod | | | Forums66 Topics128,162 Posts1,057,041 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43233 10/04/2003 1:28 PM | Joined: Oct 2003 Posts: 2 Junior Member | | Junior Member Joined: Oct 2003 Posts: 2 | can anyone tell me what i should check first when having this problem. it's a pain in the [censored] having to hold the column shift from slipping out while driving down the road.my truck is a 48 chevy all original(6 volt. 216 engine and original tranny and rear end)i can say this , it's not any of the linkage, could it be bent forks in tranny case? thanks for any advise! :confused: | | |
#43234 10/04/2003 1:45 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Common problem with three speeds that are tired. Time for a rebuild. Bowtie Bits has all the rebuild parts you need to fix that. | | |
#43235 10/04/2003 2:43 PM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | You might need a full rebuild, but...
On the shifter thing inside the tranny, there is a grooved piece which engages the rotating parts and slides them around. This grooved piece wears. Easy and cheap fix.
Pull the tranny sidecover and inspect. It will be very obvious what the problem is, if indeed this is it. Remove the old one (circlip, I think) and get a new one.
Good luck! George | | |
#43236 10/06/2003 11:43 PM | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | It's tired mine started doing that, then went out all together after about 2 months. I pulled it and put in a T5 now she gets right on down the highway at like 2000 RPM.. MONGO | | |
