7 members (MRMEROTH11, TUTS 59, Barney1951, Gray_Ghost, Wickedbass, JW51, walter74), 96 guests, and 1 robot.
Topics128,068
Posts1,055,880
Members48,428
#432318 07/13/2008 2:31 PM
Apprentice
Apprentice
I'm getting ready to install the transmission on my 57. The the installation instructions that came with the new clutch disk I bought states: Never preform a live clutch test (engine running) with the wheels off the ground. The backlash effect of the unloaded driveline could bend the drive straps of the pressure plate causing poor or no release and/or chatter upon engagement. I want to test the transmission after I install it. Right now I only have the engine on the frame. I do run the engine and the driveline is not installed yet. I want to know how to test the transmission without causing the damage mentioned above.
Rick57 #432333 07/13/2008 3:53 PM
Gotta call BS on that one! If the pressure plate was that fragile, the car wouldn't make it around the block! Just don't get crazy and do a bunch of full-throttle speed shifts. The manufacturer has to write those instructions toi discourage idiots from doing stupid stuff- - - -which they're going to do anyway! There's nothing wrong with doing a few shifts with the wheels free-spinning to check for normal operation.
Yeah,don't turn on the flashlight as it will cause battery drain and possibly burned out bulb.
