1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43171 12/24/2003 10:54 PM | Joined: Oct 2002 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 60 | what will the difference be in looks between a 4.57 and a 4.11 differental ?? I have removed my 1951 chevy 3/4 ton pumpkin and a 1968 20 series pumpkin and a 1969 30 series pumpkin they look to all be the same 32 tooth ring gear and 7 tooth pinon gear. there are numbers on the 1951 (3882103 GM 7-32 1 51) and on the 1966 (3768612 GM 7-32 8 1966 2) does the 7-32 mean 4.57 ratio thanks for any help Bill
Bill 1951 3/4 ton 5 window pick up 1955 GMC 1/2 ton longbed automatic
#43172 12/24/2003 11:08 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | 7-32 does indee give a 4.57 ratio [divide 32 by 7] - not sure what the tooth count is for a 4.11 that would fit yer truck [if there is one], but parts books might tell ya, and some wreckin yards could too
Bill | | |
#43173 12/25/2003 12:29 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think that you will find that the 411 has 37/9 teeth and the 514 has 36/7.
Anybody know the weight of the pumpkin ? I found it was a challenging thing to pick up and carry out to my car! | | |
#43174 12/25/2003 12:48 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | **** , I guess the 1 51 Means Jan of '51?. I'm currently preparing to remove my 4.11 from my spare pumpkin to swap for some 3:55. The numbers on the current big gear says:
3652510 GM 9-37 2 52.
37%9=4.11
Feb '52, I assume.
Truckernix, My wife shook her head as she saw me walking out towards my shop with our bathroom scale. With my son's help we got 100-101 pounds.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#43175 12/25/2003 3:19 PM | Joined: Oct 2002 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 60 | cmayna is right on the weight it is around 100 to 105 lbs. greyhound bus wouldn't ship one packaged up because the weight was over the 100 lbs limit at 104-105. lbs thanks for the information I will look for a ring gear with 9-37 merry christnass and happy new year to all Bill
#43176 12/26/2003 3:00 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Thanks. Now I know that old men like me shouldn't be trying to carry around 105 lbs ! Actually the only tricky part for me was picking it up and putting it down. The carrying part was OK. The junkyard guy was at least my age and he handled it like it was nothing. | | |
#43177 12/26/2003 8:20 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | **** ,,the one you want to find for a 3/4 & 1-ton will be 10-41 (like the spare I have sitting on my garage floor)
#43178 12/28/2003 2:05 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | if you know the difrent combinations is it posible to just count ring gear? I know were a posi unit is out of a 70 3/4 ton van (dont know ratio yet) are thay worth vary much? | | |
#43179 12/28/2003 3:34 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The ones that I saw in the wreckers had the two numbers stamped on the back of the ring gear. I understand that this is not always the case.
You might want to look at "Randy's Ring and Pinion" website. There might be some answers there. I found it very educational. | | |
#43180 12/28/2003 5:07 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Luke's right about the gear count. I just bought one, 10 bolt with the adjusting nut for the pinion. Ring gear is stamped with 41 10 on the inside of the teeth.
Lockers (posi) are usually worth more, especially in 1/2 tons. But to put one in an AD truck, you need to swap the differential, not just the pumpkin.
Fred 52 3600 69 C-10
#43181 12/29/2003 12:39 AM | Joined: Oct 2002 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 60 | Fred T posted posted 12-28-2003 11:07 AM
Fred by differential do you mean the complete houseing - I thought pig/pumpkin and defferential where all the same thing??
