2 members (jaycoop, Otto Skorzeny), 108 guests, and 1 robot.
Topics128,131
Posts1,056,367
Members48,441
#431502 07/10/2008 8:58 PM
Hi all,
I'm in the midst of putting a Dana 70HD in the rear of my 1950 1.5 ton Chevy. This rear axle doesn't appear to have any form of emergency/parking brake provisions built in. does anyone know if there was ever a transmission mounted parking brake made for the driveshaft output of an SM420 transmission?
Any other ideas?
Thanks!
Jon
Yes, very common in the larger trucks.
Someone had put one in my 52 1 ton, and I have a spare, honestly I can't say I remember seeing an SM420 without a parking brake, but then again I don't look under the baby trucks much...
Post a wanted add, and you'll have one pretty quick.
You may need to swap a number of parts on the back of the transmission, probably simplest to just swap the whole transmission, as they are usually pretty cheap.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks Grigg. I figured they were probably available but I wasn't having any luck just searching the internet. I saw that they were available behind Clark 5 speeds but didn't find anything for the SM420. Anyway, I'll post a Wanted ad,,, thanks again.
Jon
Jon
My 59 model 3800 1-ton had a SM-420 with a trans-mounted parking brake, a big drum on the output shaft with a brake band wrapped around it and a lever through the floor to apply it. That was pretty much standard equipment for anything 1-ton or bigger, and I believe the 3/4 ton trucks also had that parking brake setup. There should be plenty of them out there somewhere.
Ive got a couple of them, matter of fact have a 283 with sm420 with the parking brake on itfrom about a 64... pulled as a unit, also have i think about a 59 235 with tranny and brake attached pulled as a unit....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
Any chance that you would want to part with the brake assembly from either one?
Jon
i sent pm
This is what your looking for.
Bruce
My Trucks
Stuff I Collect
