1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#43171 12/24/2003 10:54 PM
what will the difference be in looks between a 4.57 and a 4.11 differental ??
I have removed my 1951 chevy 3/4 ton pumpkin and a 1968 20 series pumpkin and a 1969 30 series pumpkin they look to all be the same 32 tooth ring gear and 7 tooth pinon gear. there are numbers on the 1951 (3882103 GM 7-32 1 51) and on the 1966 (3768612 GM 7-32 8 1966 2) does the 7-32 mean 4.57 ratio
thanks for any help Bill
Bill 1951 3/4 ton 5 window pick up
1955 GMC 1/2 ton longbed automatic
#43172 12/24/2003 11:08 PM
7-32 does indee give a 4.57 ratio [divide 32 by 7] - not sure what the tooth count is for a 4.11 that would fit yer truck [if there is one], but parts books might tell ya, and some wreckin yards could too
#43173 12/25/2003 12:29 AM
I think that you will find that the 411 has 37/9 teeth and the 514 has 36/7.
Anybody know the weight of the pumpkin ? I found it was a challenging thing to pick up and carry out to my car!
1951 1 Ton Completed
#43174 12/25/2003 12:48 AM
**** , I guess the 1 51 Means Jan of '51?. I'm currently preparing to remove my 4.11 from my spare pumpkin to swap for some 3:55. The numbers on the current big gear says:
3652510 GM 9-37 2 52.
37%9=4.11
Feb '52, I assume.
Truckernix,
My wife shook her head as she saw me walking out towards my shop with our bathroom scale. With my son's help we got 100-101 pounds.
Craig
#43175 12/25/2003 3:19 PM
cmayna is right on the weight it is around 100 to 105 lbs. greyhound bus wouldn't ship one packaged up because the weight was over the 100 lbs limit at 104-105. lbs
thanks for the information I will look for a ring gear with 9-37 merry christnass and happy new year to all Bill
#43176 12/26/2003 3:00 AM
Thanks. Now I know that old men like me shouldn't be trying to carry around 105 lbs ! Actually the only tricky part for me was picking it up and putting it down. The carrying part was OK. The junkyard guy was at least my age and he handled it like it was nothing.
#43177 12/26/2003 8:20 AM
**** ,,the one you want to find for a 3/4 & 1-ton will be 10-41
(like the spare I have sitting on my garage floor)
#43178 12/28/2003 2:05 AM
if you know the difrent combinations is it posible to just count ring gear?
I know were a posi unit is out of a 70 3/4 ton van (dont know ratio yet) are thay worth vary much?
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#43179 12/28/2003 3:34 PM
The ones that I saw in the wreckers had the two numbers stamped on the back of the ring gear. I understand that this is not always the case.
You might want to look at "Randy's Ring and Pinion" website. There might be some answers there. I found it very educational.
#43180 12/28/2003 5:07 PM
Luke's right about the gear count. I just bought one, 10 bolt with the adjusting nut for the pinion. Ring gear is stamped with 41 10 on the inside of the teeth.
Lockers (posi) are usually worth more, especially in 1/2 tons. But to put one in an AD truck, you need to swap the differential, not just the pumpkin.
Fred
52 3600
69 C-10
#43181 12/29/2003 12:39 AM
Fred T posted
posted 12-28-2003 11:07 AM
Fred by differential do you mean the complete houseing - I thought pig/pumpkin and defferential where all the same thing??
