0 members (),
91
Mod | | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 21 New Guy | | New Guy Joined: Nov 2005 Posts: 21 | My front tires on my 66SWB are starting to feather on the outside with only 800 miles. My front has a 3" dropped spindle front, 4" coil rear, and 275 X 20 tires. My alignment mechanic set the alignment to factory spec and now suggested to post this if any of you have a simmilar set-up and can advise on how much to tweek the adjustment. Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'm not familiar with modified suspensions but feathering is generally toe-in being off. If you want to make shure your alignment man is being straight with you you can check the toe-in & camber yourself. There has been many discussions on setting the toe before so you might do a search. If you can't find anything & want to do it ,post it & one of us will tell how it's done. You can get a pretty good idea on the camber by putting a level on the side of the tires with the wheels straight ahead & the truck setting on level ground. They should be near straight up. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | With the modifications you've described, there is no way to align the wheels properly. The best you can expect will be to track a reasonably straight line down a smooth road, with absolutely no guarantees what will happen in a tight turn, or when making a quick movement to avoid an unexpected hazard.
Highly-modified vehicles with outrageously oversized wheels should be limited to private property, like car shows, with NO travel allowed on public roads. They're dangerous to the rest of us who have to use the public highways. Jerry
| | | | | Joined: Nov 2005 Posts: 21 New Guy | | New Guy Joined: Nov 2005 Posts: 21 | Thanks for the tips wrenchbender. Hotrod, my truck tracks straight, turns well, and the tires are 1/2" larger diam. than stock, if it were a menace on the road I wouldn't have built for my kid. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i agree with joe,take it to someone that knows what theyre doing. probly take some research but theyre out there.............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | Ave, It sounds like your toe in is way!!! off. With feathering on the outside, it is toed-out. A simple check, park on a flat, fairly level surface. Get out your steel 6ft tape measure and measure the distance the front tires are apart from each other in front of the axle at about 6 in. off the ground. Then measure how far the front tires are apart from each other behind the axle about 6 in. off the ground. These two measurements should be very close to each other, with the rear measurement only slightly larger by only 1/16th '' or so. If you find this not to be so, go back and have the shop correct the toe in.... | | |
