7 members (baldeagle, Phak1, 66flea, Gray_Ghost, 2-Ton, 2 invisible), 49 guests, and 7 robots.
Topics128,020
Posts1,055,345
Members48,420
Page 1 of 2 1 2
#431227 07/10/2008 1:31 AM
jdl
Offline
I discovered that my timing is too far advanced. How do you retard it? When I accelerate(at a standstill) I can here the pinging(or glass bottles rattling as someone else has said) so I need to know how to retard it to stop the pinging(and potential damage) in the engine.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #431230 07/10/2008 1:37 AM
Loosen the clamp bolt on the distributor and turn it a little in a clockwise direction. Bolt it back down and give it a try.
jdl
Offline
Where is the bolt? It's dark and hard to see, but I think I know what you are talking about. I've seen it in the manual.
Jordan D. Long
Photobucket
jdl #431238 07/10/2008 1:46 AM
jdl
Offline
Is it the screw between the engine and the bottom of the distributor? This screw looks like it is going through a clamp but I can't tell.
Jordan D. Long
Photobucket
jdl #431248 07/10/2008 1:57 AM
jdl
Offline
Is it the bolt with an arrow on it on this page or is it the screw just barely seen and partially covered in the picture by the distributor housing? I can't tell, I feel so novice!
Jordan D. Long
Photobucket
jdl #431252 07/10/2008 2:02 AM
jdl
Offline
I figured it out, I have to let it soak in pb blaster.
Jordan D. Long
Photobucket
jdl #431256 07/10/2008 2:09 AM
That photo shows the octane adjuster. The bolt for changing the timing is hidden by the distributor. The head faces the front of the motor.
1951 1 Ton Completed
jdl
Offline
If you look closely you can see the other end of the bolt. I found the clamp and I am soaking it in pb blaster, it is stuck.
Jordan D. Long
Photobucket
jdl #431272 07/10/2008 2:41 AM
jdl
Offline
Hey, can I use my propane torch to loosen the bolt or will I melt something?
Jordan D. Long
Photobucket
jdl #431275 07/10/2008 2:46 AM
jdl
Offline
Does this bolt turn left or right to loosen it? I have it moving, but I don't know if I'm turning it right, there are certain ones that turn right to loosen.
Jordan D. Long
Photobucket
jdl #431278 07/10/2008 2:50 AM
Righty tighty, Lefty loosey. You won't find any left hand bolts on your truck.
Bill Burmeister
jdl #431279 07/10/2008 2:52 AM
usually it is lefty loosey, righty tighty.
left will loosen it, although i am not 100% sure on your truck. everything i have worked on was left to loosen, right to tighten.
except for lug nuts on my friends 1970 dodge dart.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
jdl #431280 07/10/2008 2:52 AM
jdl
Offline
Got, now I'm going to start it and see what it does.
Jordan D. Long
Photobucket
jdl #431281 07/10/2008 2:53 AM
jdl
Offline
Yep Rat Rod, it was lefty loosey, righty tighty. Only reason I didn't know was because I turned it to the right and it moved.
Jordan D. Long
Photobucket
jdl #431301 07/10/2008 3:38 AM
jdl
Offline
Uh oh, it won't start. I don't know if the battery is getting low or if I retarded the timing too much. Just to make sure, how much should I turn the distributor?
Jordan D. Long
Photobucket
jdl #431307 07/10/2008 3:50 AM
Think about the top of the distributor as a clock face. Turn it to the right 2 or 3 minutes.
jdl
Offline
Ok.
Jordan D. Long
Photobucket
jdl #431316 07/10/2008 4:08 AM
yea, dont turn it too much. then it will be retarded too much.
have someone turn the key over while you turn the distributor until it will start. then go from there.
be careful to not get shocked holding the cap. i hate getting shocked, and use an old t-shirt when playing with the distributor while it is running.
leonard
jdl
Offline
I set it back to where it was initially. I'm not going to mess with it when it's too dark to see. Tomorrow I'll start it and then retard it.
Jordan D. Long
Photobucket
jdl #431397 07/10/2008 2:00 PM
Riding in the Passing Lane
First try it with the octane selector. It will give you about 4 degrees. Someone may have turned it way over to advance, which could be causeing the problem.
1972 Chevy c10 Cheyenne Super
jdl
Offline
Well, I would do that but I can't see the selector! I'd have to take off the fender to see it/reach it. I have to charge the battery now.
Jordan D. Long
Photobucket
jdl #431508 07/10/2008 9:41 PM
jdl
Offline
Hey got it started and running, messed with the timing for about 10 minutes and finally got the pinging to stop, but now I'm having problems with it having little "backfires" out of the carb. It's not an actually backfire, but sounds like there are little ones in the carb. Could this be from the points being incorrectly set(I tried to get them as close to specs as possible)? Or something with the carb? If I retard the distributor any more it gets worse, and if I advance it it starts to ping.
Jordan D. Long
Photobucket
jdl #431511 07/10/2008 9:53 PM
What speed are you driving, and under what conditions (uphill, downhill, heavy load, etc.)? What you're describing as "ping" doesn't happen unless the engine is under road driving load. Tune the engine to normal specifications, and stop tinkering with it until it's possible to do a proper, on-the-road evaluation of the problem.
How is a 13 year old suppose to learn if he can't 'tinker'! smile
Stuart
atomarc #431527 07/10/2008 10:50 PM
jdl
Offline
Jerry, this "ping" I discovered while revving the engine when trying to find out if my generator was charging right. It sounds like glass bottles rattling together. I was not moving the truck at all when I discovered it. And while doing a search, I found multiple times posts that recommended retarding the timing because today's gas is better than 50 years ago. But now, this "ping" is not the problem, it's the small backfire sounds coming from the carb, as explained above.
Jordan D. Long
Photobucket
jdl #431550 07/11/2008 12:42 AM
Maybe this helps...
You cannot get 'ping' by just revving while parked and not in gear.
You are probably hearing something else and should advance the distributor back to where it was, if you can.
This will cure your 'backfire' you just created by retarding too much.
Maybe what you think of 'ping' is just an old fan belt that needs some silicone spray or Armorall or simply needs replacing with a new one, if the old one is dried up and cracked.
Maybe the generator needs new bushings or rebuilding or replacing if it hasn't been lubed for a long time.
About the gas - you got it the other way around.
Modern gas is not better, but has more octane, which means you should ADVANCE the timing a few degrees to compensate.
But don't worry about your timing until you get your truck to drive on the open road and more regularly, when fuel economy and preserving the engine condition becomes more important.
If you are just wheeling around the yard, you will be fine with timing that is close but doesn't have to be ideal.
The brakes and steering would be more important to get right at this stage.
Another thing, if you haven't done this yet is to clean and rebuild the carburetor with a repair kit from your local parts store, or just buy one online.
Eventually you will also need a good rebuilt or new distributor.
Old and worn ones can give you lots of troubles, giving all kinds of false alarms.
Same with spark plugs and wires - Get a new set and properly gapped.
Get your basic cheap tools ... like a timing light, rpm gauge, vacuum gauge, spark plug gap gauge, feeler gauge and more than anything: a Shop Manual.
You will learn so much in a short time, if you follow the 'engine tune up' section of your manual, using these basic tools.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
jdl
Offline
Well, now, I'm embarrassed. I bet the rattling I was hearing was the backfire in the carb in the first place. I will go out and advance it a little from where it is now.
Jordan D. Long
Photobucket
jdl #431589 07/11/2008 2:47 AM
jdl
Offline
Ok, it is back where it was before I messed with it. (I don't know if it makes a difference or not but by revving it up I meant holding it at a certain point, not just hitting it and letting go) There is that sound in the carb. I have looked in the shop manual and the closest sound to describe it is "spitting" or "popping", probably the latter. Now that I have thought this over for awhile, both of those sounds sound like they are coming from the carb/exhaust area. They happen together. At one point in opening the throttle it sounds like a toy machine gun going off.
Jordan D. Long
Photobucket
jdl #431593 07/11/2008 3:04 AM
jdl,
could it be an exhaust leak at your manifold gaskets ?
at certain rpms if there is a manifold gasket leak it will make little popping type sounds. i changed my hedder gaskets and got rid of that annoying sound.
just a thought.
leonard
jdl
Offline
Could be, there may be a big one, there is a lot of moving air in the engine compartment, but the exhaust has a lot of holes so I can't tell. I think you may be on to something. It runs and accelerates fine, but at that certain point it makes popping sounds, and that seems very similar to what you just said. I'll get some gaskets and put them on, then see if that makes a difference. That could also be why my windshield wipers are extremely slow, where as when I first started my truck they worked fine.
Jordan D. Long
Photobucket
jdl #431626 07/11/2008 4:24 AM
jdl, im not familiar with vacuum asisted wipers, but if you are having that problem i would suspect a vacuum leak, either with the carb gasket or the intake manifold gaskets. exhaust gaskets would make the popping noise, but they would not affect your vacuum.
i do know that my hedder gaskets, that go between the hedder and the heads, they were burnt and there was a few leaks, and i would only get the small popping sounds at a cetain rpm, like around 1000-1500 rpm. anytyhing over that you really couldnt tell.
but if you do have a vacuum leak, say in the carb or intake manifold gasket, it will affect the idle quality.
i think, if while the truck is running, you can spray some carb cleaner around the bottom of the carb gasket, and around the intake manifold gasket, and it it starts to run BETTER, then you definetly have a vacuum leak in that area where you sprayed.
hope this helps.
leonard
jdl
Offline
I just looked at the engine again and I'm fairly certain that the extreme air movement(almost like a fan blowing in your face) is from bad gaskets. The exhaust pipe would not have an effect up that far, most of the exhaust air goes under the truck where the pipe is rusted in half. At any rate, I need some new gaskets.
Jordan D. Long
Photobucket
jdl #431644 07/11/2008 4:55 AM
jdl
Offline
If it does turn out to be a bad gasket(s) should I get an intake/exhaust manifold gasket set? Any other gaskets? Also, I have a carb kit but I have not a clue how to put it on and am not sure if I can even do it myself.
Jordan D. Long
Photobucket
jdl #431684 07/11/2008 11:44 AM
not sure if intake and exhaust gaskets come in a set, probably only a complete set of gaskets for the entire engine, but you can buy them separatly with no problems.
do the carb cleaner spray trick and if it doesnt affectt eh idle, than i would hold off on the intake/carb gaskets.
but do the exhaust gaskets. they are easy enough. sometimes.
keep us updated.
leonard
A manifold gasket set is readily available from local stores and reproduction parts vendors.
NAPA ($8.99)
AutoZone Part # MS9193B ($8.99 Felpro)
Advance Auto # MS9193B (FEL-PRO $9.98)
Classic Parts of America ($8.95)
All the above sets contain:
- intake-manifold to exhaust-manifold gasket
- intake/exhaust manifolds to head gaskets
- exhaust-pipe to exhaust manifold gasket(s)
The Classic Parts set includes two styles of exhaust pipe gaskets (to fit all years, 54-62).
You might want to buy two sets. The modern manifolds-to-head gaskets are thinner than the original gaskets and less forgiving to mismatched surfaces. You would then need to have the mating surfaces on the manifolds planed or hope that a double thichness of gaskets will work.
Also, it is not uncommon that the intake-manifold-to-head alignment rings have been mangled, it might be a good idea to get a set of alignment rings.
jdl
Offline
Ratrodking, I went onto Napa and they have a combo set. Tclederman, thanks. If the only gasket(s) that are blown have to do with the exhaust it won't affect the engine, it'll just make those sounds right? And if there are other bad gaskets, like one for the manifold, it won't hurt to not replace them right away?
Jordan D. Long
Photobucket
jdl #431836 07/11/2008 9:41 PM
jdl
Offline
Some good news! The popping sound IS made by the bad gasket between the exhaust pipe and manifold(? I really have to find out what all of those are called) and I know why my wipers aren't working very good. When I put my hand up to the port(if that's what it is called) that the vacuum wiper hose is connected to, I feel some air, just like I do at the exhaust gasket. But I can't track where it is coming from. I also feel air in the space between the carb and fan, don't know if it is from the fan or not.
Jordan D. Long
Photobucket
jdl #431895 07/12/2008 12:19 AM
If you think the wiper hose connection (or hose) is bad, you would feel suction (from the vacuum).
jdl
Offline
No, it's not sucking in, it is going out, which makes me believe that it is coming from between the carb/spacer or spacer/manifold.
Jordan D. Long
Photobucket
jdl #431938 07/12/2008 2:19 AM
jdl
Offline
Would it make a difference if I had the wipers on and it sucked in? I'll go out and see.
Jordan D. Long
Photobucket
Page 1 of 2 1 2
