| | | Forums66 Topics128,035 Posts1,055,556 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43113 07/13/2004 11:55 PM | Joined: May 2004 Posts: 30 Member | | Member Joined: May 2004 Posts: 30 | Well, my tires are getting old and I've seen alot of these trucks with fat white wall tires on them. I started to look online at Coker and denman tires but I can't figure out what size I have and also if I should get bias ply or radials. I plan to drive the truck alot and want the radials but I'm worried they won't look correct and my steering will be harder. I want to mount the new tires on the original rims. | | |
#43114 07/14/2004 4:34 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | What year of truck? 1/2 ton? and what is the size of your tires? Are your rims one piece?
Fred 52 3600 69 C-10
#43115 07/14/2004 5:05 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | Try Diamond Black Classics too - http://www.widewhitewalltires.com/index.htm I use radials on my daily driver 63 Nova and they provide great handling.  Making sure the front end is in good shape helps! On older trucks, upgrading to roller front wheel bearings is also a good idea. Jim
Jim
