Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 68 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#431078 07/09/2008 5:48 PM
c53
Offline
Got a 235 setting in the truck now and really need the bellhousing and flywheel off the old 216. Never figured it would seize setting under cover, but it did. Got to get the engine to turn to get the clutch off to get the bellhousing off. Won't turn by the flywheel gear, tried strap wrench on front pully, tried extended bolts off the front pully, tried 3/4 adapter in the crank slot tried pry bars in pressure plate holes. All of course with PB and WD40 in the cylinders and it's still locked.
I'm gone a pour diesel fuel in the cylinders and walk away for a couple days.
Anybody got a better idea?
c53,
A long flat nose bar wedged on the bell housing and stuck in the ring gear exerts a tremendous amount of turning force. If this trick didn't do it then you have some serious fungus holding things together.
You're on the right track with the juice in the cylinders and some time to soak. That's my two cents.
Stuart
Kroil, best stuff I've ever seen to free up a locked engine! Get it direct from the manufacturer.
www.kanolabs.com
jdl Offline
I let some pb blaster and oil soak in my cylinders for two weeks(due to me being out of commission, at least for the truck) and then took the flywheel cover off, took a pry bar to the flywheel and when I just barely pushed it came free.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
c53
Offline
Thanks for the input guys.
I went home and soaked it over nite and still locked. The dictionary says Patience is "being capable of tranquillity while awaiting results" So I'm juicing her down and leaving for the beach for a couple days to be tranquil.
I'll let you know if it works!!
