| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 39 | Good morning! As I read through various discussions I see the mention of "balast resistor", "igintion resistor" and "voltage reducer". I'm converting to a 12volt with the original 1949 foot start 216 ci engine. I have purchased a 12V coil with "no external resistor rewuired 1005" written on it. It is a BWD select E502.
SO the question is; if I have an internal resistor (in coil and I assume it is a balast resistor) do I need an ignition resistor? Plus I assume there is no need for a side terminal on the starter switch and a wire to the start (key) switch, etc.
THX for your help, | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | ia49,
You have it figured out...the coil with the internal resistor takes care of all your concerns, no other goodies required.
Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Balast resister & ign. resister are the same thing. Voltage reducer is used to cut the voltage down for 6 volt acess. You must use one for your gas gauge or you won,t get a 2nd chance. It,s correct the no resister required coil doesn't need a resister or bypass, but personaly I wouldn't use one. They are designed for tractors & low RPM engines. Maybe a 216 might be considerred a low rpm engine but the manufactors never used them on highway vehicles. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Internal resistor 12 volt coils were standard on a 1950 John Deere A which was around 320 cu in engine with 2 cylinders which ran around 900 rpm if that tells you anything. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Ford ran millions of internal resistor coils for at least 30 years, on street machines! The only disadvantage with them is a slightly lower spark voltage during starting because it's impossible to bypass the resistor while the starter is running. If battery voltage drops to 10 volts during cranking, for instance, the internal resistor reduces this voltage even more, resulting in a weak spark when you need a hot one most. GM systems used the "S" terminal on the starter solenoid, or the "S2" terminal on the ignition switch to bypass the resistor and put straight battery voltage to the coil primary. When the starter disengaged, the resistor kicked in and dropped the voltage back to approximately 9.5 volts to the coil primary terminal during normal running. This saved the points from premature failure with the low-resistance coil primary winding. Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ford went to 12 volt system in 1956. All the ones I worked on had a ceramic resister similar to GM. A few years later they went to a resistance wire that pigybacked the harness. They used a selinoid/relay that had an extra term. for bypass but some models used a bypass in the ign. switch. Coils that do not use external resisters do not have a resister built into it. They have more windings on the primary circuit thus giving it more resistance. This coil cannot cycle fast enough for high RPM multi cyl. engines so must be used only on low RPM &/or 1-2 cyl. engines. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
