| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43015 04/27/2004 3:09 AM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Can anybody out there tell me where the Overflow Return Tank (Option #271) is supposed to be mounted on the 41-46 chevy 1/2 ton? Better yet, can anybody post a photo of one of these installed (including where the lines are run)?
Thanks if you can help!
Tim
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
#43016 04/27/2004 3:42 AM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | I don't have your answer but I do have a question. Are you talking about a Radiator overflow or someother kind of overflow?
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#43017 04/27/2004 3:52 AM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Yes the radiator overflow....sorry I wasn't clear.
#43018 04/27/2004 4:05 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | Don't know about the truck, but on my 41 sedan it goes on the firewall over the battery. It even had some indents for the screw holes so look close...
Jim
Jim
#43019 04/28/2004 5:33 AM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Thanks...I'll take a look. Anybody out there have one of these installed?
#43020 04/29/2004 7:30 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | Yes, I do. It stops those embarassing wet spots after a long hard drive.
Jim
#43021 04/30/2004 7:54 PM | Joined: May 2003 Posts: 111 Member | | Member Joined: May 2003 Posts: 111 | Jimfred, Isn't that what reststops are for?
35 + years of rollin' steel!
