| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#43004 03/08/2005 9:28 PM | Joined: Mar 2005 Posts: 4 Junior Member | | Junior Member Joined: Mar 2005 Posts: 4 | I'm planning to install a mostly stock 350/350 in my '67. It has the trailing arm/coil spring rear end. Was/is there a 12-bolt that will bolt in? Is the 10-bolt stout enough? I do not plan to race the truck (well, not a lot, anyway).
The nut holding the (old Chevy) steering wheel
#43005 03/09/2005 9:35 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 10 and 12 bolt rears are interchangeable. For daily driving, the 10 bolt will last a long time. But the 12 bolt is stronger. I found a 12 bolt locker that is going to go in my 69. Right now I'm doubling the h.p.
Fred 52 3600 69 C-10
#43006 03/12/2005 8:23 AM | Joined: Jun 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2001 Posts: 85 | 12-bolt Corp rear end was stock on '67 1/2 ton trucks.
Every 25 years I like to rebuild that 292 just for GP
