5 members (FishinToms53, klhansen, Hanks custodian, 5 Window 9434, Mike Roache), 64 guests, and 0 robots.
Topics128,049
Posts1,055,634
#429668 07/05/2008 7:27 PM
I am beginning to work on the clamshell on my 49 suburban. Does anyone know of a vendor that will have the cables for the bottom door and also the metal slides that will hold the top clamshell open? If not has anyone rigged current OEM style lifts and would know what length etc to use?
The hinges of the clamshell has some shoddy fabrication done by the PO so if someone can take a picture of what they are supposed to look like I would be grateful. Thanks for any help.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
I purchased on e bay a truck lift slide that works fine.
Dave Murray
[email protected]
On my "58, the cables for a Nomad Wagon are the correct length (46 7/8") with the swaged ball on the end, from Danchuk (Catalog part# 221)Direct link as follows:http://www.danchuk.com/03_06_tailgate_cable.html#200ct
They also sell the retractors. Good Luck!!
1958 GMC Suburban Carryall
Never accept a drink from a urologist!
thanks guys I check ebay and danchuk
I was also looking, thanks for the info.
RABBOTT
RABBOTT #434490 07/21/2008 3:19 AM
I've been told that motorcycle shops should be able to make the ball-and-cable part for the lower door if yours is frayed.
52 suburban rat rod. 350/350, 9-inch ford rear, independent suspension with 2-inch drop spindles, power rack, two-tone Mexican blanket interior, paint by mother nature
