| | | Forums66 Topics128,049 Posts1,055,677 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 92 | on my 48 1/2 ton the front brake line crossover is leaking somewhere...it looks like I will have to pull grill and radiator to even get to the tee on the frame...does this sound like a good idea? On page 85 of LMC it shows a diff. routeing for the brake line but it might show for a longbed instead of shortbed...any good answers...Thanks....Virg | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Move the crossover? On a little later trucks that crossover happens at the bellhousing crossmember.
One line from the master goes forward to the left front brake. A second goes to a tee just behind the bellhousing crossmember, where a line forward goes to the right front, and a line back feeds the rear brakes.
If you have one leaking metal tube you probably want to replace all of them to be safe. Once you've made that decision rerouting isn't as difficult to accept...
I'm not sure when the change occured. I have a '50 1-ton with the line running under the radiator and a '54 1-ton with a hydravac where it happens even further back under the cab.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
