3 members (Gray_Ghost, greenie-reddy, carbking), 55 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#429213 07/03/2008 6:48 PM
Apprentice
Apprentice
i have a 1958 chevy apache truck....i have just purchased the horn amd bearings (assembly). i am looking for a scamatic on how it all goes together... any ideas thanks doug
gina #429273 07/03/2008 10:24 PM
Let me hazard a guess, here: Are you referring to the stuff at the top of the steering column?
1951 3800
-hotshoe
hotshoe36 #429279 07/03/2008 10:41 PM
"schematic"? the wire off the bearing assembly comes out the side of the column where there's a cover plate and plugs into the wire under the dash
check the shop manual and/or assembly manual .... if you don't have either, you should have smile maybe some one will have a picture, but the bearing install requires the wheel be removed, and then it'll be obvious - when you've got the wheel off, how the button mechanics go on might also be obvious
