| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42923 02/25/2003 3:04 AM | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | I have a 67 C10, with a 250 engine. Awhile back, someone converted it to floorshift, sorta. I say sorta because they put it in backwards, and because of that, my "H" pattern is backwards. I think I can straighten that out fairly easily, but I would prefer to put the linkage back on the column. Would appreciate knowing what year trucks, if any, have linkage that will interchange with my truck. Also, would appreciate any leads on where I might locate the linkage. Thanks in advance. | | |
#42924 02/25/2003 7:19 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | For the linkage, you'll need to find someone with a donor truck. Try putting an ad in the swap meet. You'll probably find that the reason for the conversion was due to the bushings in the column were worn out, so you'll need to replace them with new.
Making the floor shift pattern backwards is an old trick, some guys did it back when I was in high school, but I can't remember what they did to make it happen, but it wasn't that hard.
Fred 52 3600 69 C-10
