4 members (Wally / Montana, Otto Skorzeny, baldeagle, joe apple), 72 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#428533 07/01/2008 11:05 PM
I have a 48 Chevy 1/2 ton. Everything is stock. What size tires should I buy for my 15x8" chrome smoothie wheels? I would like a lower profile but that will affect my top speed....looking for any suggestions. thanks
255/70/15 would be a good choice, you won't want anything too low in profile as they don't have the load capacity to carry the weight of the truck.
Bill Burmeister
15 x 8 are probly not original. 16 x 5 or 6 would allow you to run 235/80R16's and then you'd have a decent top cruising speed.
1951 3800
-hotshoe
I dont want to go with a really wide tire. Would a 215/70 be good? Or a 215/60?
Yes. But you'll lose road speed.
1951 3800
-hotshoe
With a 60 profile, what top speed would I be looking at? How about with a 70 profile? Big difference? I might change the rear axle gear ratio later on.....
Without knowing what tire size you now have and what your top speed is now, your question is impossible to answer.
Also, I would guess a 215 is too narrow for an 8" wheel.
weltertm, i went from 235-75-15 to my current 225-70-15, and added about 200 rpm at 60mph. thats with a th350 3 speed automatic.
the 225-70's are right at 27 inches tall, and the 235-75's were about 28-28.5 tall.
hope this helps.
and if you look at my web album you can see before and after pics..
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
215s will be way to narrow for an 8" rim, as well as being even shorter than a 235/255 tire with the same aspect ratio. A 255/70/15 comes out to a 10.5" section width and is right at about 28" tall, give or take a 1/4" either way depending on brand. A 235/75/15 would also be an exellent choice, but I wouldn't go any narrower than that with an 8" wheel. Another option would be a 30x9.50x15 C floation size, which will give a good ride and still keep load capacity. That's what I'm running, on a set of 15x8 Blazer Ralleys.
Bill Burmeister
