3 members (55shaker, MOTOXFAMILY, SNOYL), 178 guests, and 4 robots.
Topics128,268
Posts1,058,379
Members48,485
#42878 03/27/2004 4:32 PM
Junior Member
Junior Member
' Offline
I'm having a hard time finding NOS exhaust valves for my 302. Does anyone know of any newer valves that will work to rebuild my head? Thanks
#42879 03/27/2004 8:31 PM
Did you try the vendors on the "links" page on this site? Seems like there are a few GMC oriented one's.........Patrick's maybe?
Otherwise, try egge.com......lot's of old stuff available from them.
#42880 03/28/2004 6:50 AM
I have several older TRW and Perfect Circle engine parts catalogs at my shop in Nashville. They have a "specifications" section that gives dimensions of engine parts such as pistons, valves, etc. I was able to match up some valves for an older Oliver tractor that way, but we had to change the valve guide size. I'll check into possible interchanges when I get to work Monday.
#42881 03/30/2004 4:41 AM
Most performance rebuilds on 302 heads include installation of Chevy V8 intake and exhast valves. 1.94 intake and 1.5 or 1.6 exhausts. This is only a modest increase over stock - You will need hardened seats in the exhaust anyway, and the Chevy seats are readily available. Any additional cost for reaming guides or cutting new spring seats should be offset by the dirt-cheap cost of the valves. Check with your machinist and weigh the options.
Moderated
Moderated
I know the 1.94 and 1.6 sbc valves will work but can some one give me a idea how long of valve they used ?
Hmmmm- - - - -a 14 year old zombie thread returns! Why not measure your 302 valves and start from there? Or is this just some sort of hypothetical question?
Moderated
Moderated
I did mic how long the valves are. Sbc Chevy are to long or to short and I wanted to know which ones there using ? With out grif of blocks under or cutting the rocker stands to correct rocker angle.
Crusing in the Passing Lane
There is info on adding a ff oil filter on 'Inliners'.
Ed
go to a head shop,
Valve stems are easy to shorten and new keeper grooves can be cut on a lathe. They are NOT hard as if brittle they would snap in two. A motorcycle shop used to bring us 390 Ford valves that fit some old Harley and we would shorten them---a lot, and cut new keeper groves. On race engines we got long stem valves and cut them so the rocker roller was on the exact center of the valve stem at half lift. Using off the shelf stuff sometimes had the roller running off the end of the stem and onto the retainer.
Evan
