1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | I have a 48 Chevy 1/2 ton. Everything is stock. What size tires should I buy for my 15x8" chrome smoothie wheels? I would like a lower profile but that will affect my top speed....looking for any suggestions. thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 255/70/15 would be a good choice, you won't want anything too low in profile as they don't have the load capacity to carry the weight of the truck.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 15 x 8 are probly not original. 16 x 5 or 6 would allow you to run 235/80R16's and then you'd have a decent top cruising speed. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | I dont want to go with a really wide tire. Would a 215/70 be good? Or a 215/60? | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Yes. But you'll lose road speed. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | With a 60 profile, what top speed would I be looking at? How about with a 70 profile? Big difference? I might change the rear axle gear ratio later on..... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Without knowing what tire size you now have and what your top speed is now, your question is impossible to answer.
Also, I would guess a 215 is too narrow for an 8" wheel. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | weltertm, i went from 235-75-15 to my current 225-70-15, and added about 200 rpm at 60mph. thats with a th350 3 speed automatic. the 225-70's are right at 27 inches tall, and the 235-75's were about 28-28.5 tall. hope this helps. and if you look at my web album you can see before and after pics..
leonard | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 215s will be way to narrow for an 8" rim, as well as being even shorter than a 235/255 tire with the same aspect ratio. A 255/70/15 comes out to a 10.5" section width and is right at about 28" tall, give or take a 1/4" either way depending on brand. A 235/75/15 would also be an exellent choice, but I wouldn't go any narrower than that with an 8" wheel. Another option would be a 30x9.50x15 C floation size, which will give a good ride and still keep load capacity. That's what I'm running, on a set of 15x8 Blazer Ralleys.
