4 members (1955 1 Series, Maybellene, kbenz, cmayna), 80 guests, and 1 robot.
Topics128,157
Posts1,056,872
Members48,456
Apprentice
Apprentice
what is the trick to removing the back door lock? i was able to get the screws out of the bracket and the handle off.
I believe if you look on the inner edge of the door you will see a slot where a spring clip slides over and holds the lock cylinder in place. Mine was already out but thats how I put it back in.
David
Just a firefighter,
Cleverly disguised as a responsible adult
'46 1/2 T Panel
Apprentice
Apprentice
thanks. i did see a little slot there but will give it a closer look to find the spring clip.
