0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 14 Junior Member | | Junior Member Joined: Mar 2004 Posts: 14 | Hey, folks!
New to the forum here, and have a few questions about some plans I have for a '54 3600 I just bought.
I have a '83 Chevy conversion van equipped with a 350/700R4 that I am not interested in keeping. My thoughts are to install the engine/tranny/rear/front suspension from the 3/4T van over to the '54. Haven't done any measurements, yet, just in the dreaming stage.
Any experienced modifiers out there have any red flags to throw out there for me?
Tim
Tim
| | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | The 700R4 has a lockup torque converter, so be sure and include the wiring to apply the converter clutch. The early models used a vacuum switch and an internal switch in the transmission to provide lockup at the correct manifold vacuum and speed, while later models used a computer circuit and the throttle position sensor to accomplish the lock/unlock cycle. Your 85 should have the vacuum switch system if it's carbureted. If the engine has the electronic-controlled Quadrajet carburetor, it's wise to switch to an earlier model carb without the computer controls for your application. Stay away from the Holley carb conversion most people would reccomend. The Q-jet is a better carburetor, and it's designed to work with your engine. The Holley is a "will-fit" conversion, and probably won't be calibrated for best performance and economy. Jerry
