11 members (Jay R, wilbur53, Gdads51, TUTS 59, DaveV, RLB, WICruiser, Phak1, Otto Skorzeny, 55shaker, 1 invisible),
109
Mod | | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2000 Posts: 21 | I have install new cab mounts in my 48 Chevy Pickup. The 48 pickup has the normal two mounnts in the front corner, but has only one center mount on the rear. Each rear corner has a solid rubber mount bolted to the cab and it rests on top of the frame rail.
The mounting kit did not include the rear corner mounts, to date I have not been able to locate the rear corner mounts.
Has any one had this problem and found a mount that will work?
1948 Chevy 5 window "6" powered
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The rear corner "mounts" on a 48 are just simple rubber bumpers, I don't think they are called mounts.
I am curious what you find, as I will need some soon too.
Grigg | | | | | Joined: Jan 2006 Posts: 205 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 205 | I used hockey pucks. They worked perfect.
Tom
48 Chevy 3100 Shortbox 5 window "The Big Dog"
