5 members (Uncles51, 55shaker, Woodcmiami, Stovebolt48, joe apple), 65 guests, and 3 robots.
Topics128,021
Posts1,055,351
Members48,420
#426767 06/26/2008 4:09 AM
I spent time on a search zero luck!!! Where, who makes the side motor mount adapters for the 235 to bolt, not weld,to the frame of a 38? I am not qualified to trust anything with a weld. I found numerous articles on 40 on up, nothing on 37/8, even tried to chase down Chassis Engineering site as was mentioned for a 1940. I know not too many 38's so not a lot of coverage, maybe my Luck will Change?
gene bryson
wheezer geezeer #426850 06/26/2008 1:41 PM
Ex Hall Monitor
Ex Hall Monitor
I always assumed the 235 used the same motor mount locations as the stock 216. The 216 bolts down. No welding required. Meby I was wrong???? ohwell
Tiny #426909 06/26/2008 6:36 PM
Riding in the Passing Lane
Some of the late 235s had side mounts but you may wany to mount it like Tiny says.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #427014 06/27/2008 12:04 AM
You can drill your front plate if the engine only has side mounts. INSTRUCTIONS
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
wheezer geezeer #427060 06/27/2008 2:29 AM
Yes, Yes, And Yes On the replies, Thanks Guys.
I have a "Special" installation. The 235 is in and has been for 25 years, because I have removed the truck Transmission and Bellhousing the sedan Bellhousing mounts don't sit over the rear X member which is riveted in. By using the side mounts (WITH ADAPTORS TO THE 38 FRAME)I can slide the Transmission, X member, which is bolted, up to support the Transmission. Or fabricate a Transmission mount. The side mounts would support the 235, and absorb the engine torque.
Some one makes these frame mount adaptors for a 38, DON'T THEY??? An Alternative would be a spacer between the Transmission and Bellhousing that has the correct angle to use the Truck motor mounts. I seen one during my search dated 2001.
Thats why the request for suggestions, or leads.
How about it, don't let your knowledge and suggestions go to waste.
gene bryson
