4 members (Oswald, treegrower, Nick in Manitou, 1 invisible), 40 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#426522 06/25/2008 5:52 AM
Anyone run 19.5s on there 1 tons.People keep telling me to switch to 16 inch wheels.I really want to keep it original but am having a hard time finding 19.5s.
581ton #426536 06/25/2008 9:53 AM
I'm running 19.5's on my 1950 1 ton. You can see it in the link below.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #426550 06/25/2008 1:41 PM
Riding in the Passing Lane
I would keep the 19.5s. Single wheel 19.5s are hard to come by. Hubcaps harder yet. The tires should be readily available but expensive. You might check tire shop that do a lot of motor homes. The motor home people often replace tires before they are wore out for safety & dependability.
1972 Chevy c10 Cheyenne Super
I ran 8-19.5 and 8R19.5 on my 52 1 ton, and really liked them.
When I put the truck back together I will once again use 19.5 tires.
Not sure if it was just me, but the 19.5 tires rode many times smoother than the 7.50-17 tires I had before.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #427630 06/28/2008 11:47 PM
1 Offline
So, are you running singles or duals? In any case, make certain that whatever you run will clear your brake drums.
Tire selection is greater in 16" sizes. If you are concerned about overall height, there are 16" tires that are as tall as 19.5" tires; I have some 16" NDTs that are taller than most of my 19.5" road tires.
Something else to keep in mind is that wheel/tire changes are likely to affect your unsprung weight (mass) which in turn will affect the driving characteristics of your truck.
Good luck.
- AJ
1956 #428042 06/30/2008 5:05 AM
Truck has duals.I found new ones at tirerack.com for $204. each.A little pricey but at least I know they exist. Mine have very little tread wear but are showing some signs of dry rot cracks on the sides.I probably wont be ready to roll it down the road till next summer so maybe ill get lucky and trip over a used set.
