2 members (Hotrod Lincoln, Woodcmiami), 72 guests, and 3 robots.
Topics128,029
Posts1,055,417
Members48,422
#425762 06/23/2008 2:46 AM
LB
Offline
How do I remove the shift arm collar on my 50 GMC?
LB #425884 06/23/2008 12:26 PM
If it's a 4-speed, you push down and turn it. If you look at the sides you'll see two pins in a slot. Once you see that, the procedure should be obvious.
Of course this may not be what you are referring to, but I tried.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
LB
Offline
Thanks, Woody. I should have mentioned it was on the column. I appreciate your input anyway! Lon
