7 members (baldeagle, Southerntruck, Hanks custodian, Woodcmiami, J Lucas, Rusty Shackleford, TooMany2count),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,133 Posts1,056,398 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 | I've had to replace the worn out non GMC truck radiator with a new correct style GMC truck radiator . The problem is the fan is now in Contact with the back of the radiator  . Is there a short shaft water pump made for the 1952 GMC 302 6cyl ? I am not a engine whiz but would the 235 6cyl short shaft water pump fit the 302 ? Any help to this question would be happily taken . Thank you ED
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The stock radiator should give plenty of clearance. Is it posible the mount was modified for the other radiator? I'm not aware of a "short" pump for a GMC engine. Lot's of guys on the discussion board at www.oldgmctrucks.com run 302s. You'll have to sign up and do a search. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Are you sure you got the right fan and pulley? | | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 | I checked the radiator mount found no modification . Have the correct fan/pulley even the original motor . The old bad non-GMC radiator only had about 1/4" clearance . Back to PONDERING hair pulling and colorful language . Thanks For the suggestions ! | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Perhaps your new radiator is a 4 row or similar, a Desert Cooler type? | | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 | Wellllll Folks I'm here with egg on my face . NEVER listen to what people tell you it IS look for your self and research . The bloody engine is a 248 not a 302 and the truck is a 303-24 not a 450-30 . The wheel base of 185" does not fit any manuals list I have seen . OH WELL ! Back to the radiator . It is a desert cooler 4 row radiator . I can cut the mounting flang off and slide the whole radiator into the old radiators mounting frame and it should work . After measuring forteen ways from sunday that is . At least that's the plan at the moment . Thanks again for the help ! ED | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | It shouldn't make any difference if its a 248 or a 302 or a 300 or a 450. Back in the 50's I put radiators out of 450's in pickups and ran 228 248 270 and 302. Radiator clearance never was a problem, but keeping cool was. I finally fabricated shrouds and that fixed it. Is it possibly a Chev fan. I have some chev motors laying around that came out of GMC parts trucks and it looks like the fan sticks out farther. | | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 | Thanks I will have to check the fan. I do know it's 2" front of blade to back of blade. ED | | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 | Had a friend call me and ask me about the fan blade measurement . To clear up my somewhat simple answer - the 2" is the area the fan blade occupys - takes up - space it uses - it's pitch - not the physical width of the blade itself . Now that that's as clear as mud I'm back to work as soon as the new waterpump comes in . ED a clueless newbe new guy FNG ect... Yall have a good day . | | | | | Joined: Jun 2008 Posts: 238 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 238 |  The end of the story ! Ok the engine was a 248 not the 302 . I got a new GMC desert radiator and the fan would not fit with the new radiator . Got a new smaller pitch fan and that did not work (it just touched the radiator ) . Had to do what I was not wanting to do - modify the new radiator . Cut the mounting flanges off . Took the spot welded - mounting yoke with it's mounting flanges off of the old radiator . Some chopping and fitting on that and the new radiator slid into the the modifyed yoke-flange setup . Slid the whole thing into the trucks radiator frame and  it fit like a glove . Bolted her up put in a new thermostat put on new hoses added fluid and fired the puppy up . YAY!!! No problems and the next day ran the Big Bolt in her first 4th of July parade and again no problems . I don't know if my trucks set up different in it's radiator mount set up but the new repro-radiators mounting flanges arn't recessing the radiator away from the engine enough and the angle is off also . Live and learn . Thanks to all who have sent tips  . ED | | |
