11 members (David Bush, msmall, Southerntruck, Tyler Watts, Hush, JW51, Hotrod Lincoln, jasrking, Joe H, Gray_Ghost, Forty9),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 3 New Guy | | New Guy Joined: Jun 2008 Posts: 3 | I just bought a 70 GMC short bed can any one tell me where I can find the vin# on the frame, I was told the top of the frame next to the steering box but is not there. And trying to touch up the frame is the pits.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think by the 70's they'd moved it further back, under the front of the cab - you shouldn't have to do any damage to see it if you find where it is, it'll be quite clearly stamped in so paint doesn't fill it, unless someone purposely filled the stamping .... in which case you might not want to find it  Bill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | For a while they were on the right hand side above the springs, but that was in the I beam axle days. | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | hey 70 in vegas ill look myself you got my intrest up now and ill look at my 68 gmc | | | | | Joined: Jun 2008 Posts: 3 New Guy | | New Guy Joined: Jun 2008 Posts: 3 | That would be a great help, thanks. | | |
