| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 35 Junior Member | | Junior Member Joined: Apr 2004 Posts: 35 | The #HCA939219 is stamped on the block down by the distributer. I tried to find out what size motor this is but it wasn't listed in the casting numbers. Anybody know how to sipher this # ?? Also, on the rear end, stamped on top between the two ribs are the #'s "TL727" and "N657". Do these tell me what ratio the rear end is?? If so, what is it. Any help is appreciated. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | That first number looks like your serial number. For engine ID you need to look farther aft on the side of the block, sometimes behind the starter. There should be a raised number that is part of the casting. Probably under a lot of grease. Go to www.inliners.org to learn which engine it's from.
Fred 52 3600 69 C-10
