3 members (Otto Skorzeny, Shaffer's1950, 1 invisible), 164 guests, and 5 robots.
Topics128,088
Posts1,056,122
Members48,435
#42588 12/20/2003 2:52 AM
I need help with what codes to look for on '67 &'68 gmc-chevy rear axles.There must be some type code on them to indicate the ratio of the axle if I look in the right place. Also, were these years 10 bolt or 12? Any links of where to educate myself on this is appreciated. Thanks, dyna
#42589 12/20/2003 3:10 AM
not 100% sure, but "almost every" vehicle has a "tag" placed under one of the bolts that holds on the gear cover. It should say on it (stamed in it) what the ratio is.
the tag is probably about 1" by 1/2" made out of thin sheet metal.
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#42590 12/20/2003 4:05 AM
Over the years the tag often gets removed,,, AND LOST.
The 10- bolt rear will have 10 bolts on the cover and the 12-bolt will have 12 bolts holding the cover on.
This is a half ton pick-up I take it??
There should also be stamped numbers on the axle tube to one side or the other on the forward side,,, use a wire brush to look around the numbers are there.
http://www.nastyz28.com/camaro/zsusp.html#rearaxle
