1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#42541 10/10/2004 11:18 PM
Just replaced the seal and carrier bearing in the enclosed portion of the driveline on my 1950 3/4 ton. It was doing find, no leaks until today. I noticed a drop coming off the carrier bracket. When I felt it, it was all full of think black fluid. By the way, I changed the transmission fluid with Redline Synthetic. I would assume the black is the new seal I installed but have no idea why it is leaking or apparently chewing up the seal.
Any ideas from anyone?
#42542 10/11/2004 8:58 PM
If your seals were almost worn out synthetic will tend to make them leak. It has much better detergent properties than dino oil and tends to clean out the crud that was keeping them from leaking. It also tends to flow a bit better than dino of the same weight so if it finds a leak it will leak out faster.
Paint & Body Shop moderator
#42543 10/11/2004 9:10 PM
All seals in the torque tube are new so I don't know why synthetic would be an issue.
#42544 10/12/2004 1:52 AM
if the seal is getting chewed up it would mean you have a roughf spot on the metal or you failed the grease and lube the seal and surface area around it it may need brake in time or you might have to replace it again this time grease it up good
