8 members (Joe H, Joe Lowe III, frogfarmer, Shade Baby, 3B, Oswald, Cosmo, 1 invisible),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42541 10/10/2004 11:18 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Just replaced the seal and carrier bearing in the enclosed portion of the driveline on my 1950 3/4 ton. It was doing find, no leaks until today. I noticed a drop coming off the carrier bracket. When I felt it, it was all full of think black fluid. By the way, I changed the transmission fluid with Redline Synthetic. I would assume the black is the new seal I installed but have no idea why it is leaking or apparently chewing up the seal.
Any ideas from anyone? | | |
#42542 10/11/2004 8:58 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If your seals were almost worn out synthetic will tend to make them leak. It has much better detergent properties than dino oil and tends to clean out the crud that was keeping them from leaking. It also tends to flow a bit better than dino of the same weight so if it finds a leak it will leak out faster.
#42543 10/11/2004 9:10 PM | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | All seals in the torque tube are new so I don't know why synthetic would be an issue. | | |
#42544 10/12/2004 1:52 AM | Joined: Aug 2004 Posts: 196 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 196 | if the seal is getting chewed up it would mean you have a roughf spot on the metal or you failed the grease and lube the seal and surface area around it it may need brake in time or you might have to replace it again this time grease it up good | | |
