1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42529 09/22/2002 4:30 AM | Joined: Sep 2002 Posts: 9 Member | | Member Joined: Sep 2002 Posts: 9 | I think that the engine in my 50 burb has been pulled. I am not sure if the engine that is in it now is the original. I am having trouble identifying whether or not it is still a 216 or a 235. I am not sure where the block casting number is located. I did remove the valve cover and found the head casting number--GM 3835517 with a 30 underneath that. Is there any place to look up head casting numbers to identify the ci of my engine. And will this tell me anything anyway? :confused: | | |
#42530 09/22/2002 4:36 AM | | Anonymous Unregistered | | Anonymous Unregistered | We can tell you the month, day & year & in some cases the workshift that cast your motor !! We need the block casting #'s from the area near the starter [ probably covered with years of crud ]. # should begin with " CON............." Let us know | | |
#42531 09/22/2002 4:44 AM | | Anonymous Unregistered | | Anonymous Unregistered | Head casting # 3835517 decodes to a 1950-1953 216 motor. | | |
#42532 09/22/2002 5:14 AM | Joined: Sep 2002 Posts: 9 Member | | Member Joined: Sep 2002 Posts: 9 | Is it possible to put the head from a 216 onto a 235 block? And thanks for the help. | | |
#42533 09/22/2002 5:20 AM | | Anonymous Unregistered | | Anonymous Unregistered | Is it possible to put the head from a 216 onto a 235 block? And thanks for the help.
This will NOT work. | | |
