0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#42529 09/22/2002 4:30 AM
I think that the engine in my 50 burb has been pulled. I am not sure if the engine that is in it now is the original. I am having trouble identifying whether or not it is still a 216 or a 235. I am not sure where the block casting number is located. I did remove the valve cover and found the head casting number--GM 3835517 with a 30 underneath that. Is there any place to look up head casting numbers to identify the ci of my engine. And will this tell me anything anyway? :confused:
#42530 09/22/2002 4:36 AM
Anonymous
Unregistered
Anonymous
Unregistered
We can tell you the month, day & year & in some cases the workshift that cast your motor !!
We need the block casting #'s from the area near the starter [ probably covered with years of crud ].
# should begin with " CON............." Let us know
#42531 09/22/2002 4:44 AM
Anonymous
Unregistered
Anonymous
Unregistered
Head casting # 3835517 decodes to a 1950-1953 216 motor.
#42532 09/22/2002 5:14 AM
Is it possible to put the head from a 216 onto a 235 block? And thanks for the help.
#42533 09/22/2002 5:20 AM
Anonymous
Unregistered
Anonymous
Unregistered
This will NOT work.
