2 members (Peggy M, cmayna),
226
Mod | | | Forums66 Topics128,282 Posts1,058,495 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42500 03/24/2003 3:38 AM | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | I was reading an article on Disc Brake Conversation http://www.classictruckshop.com/t3.asp The article talks about using a remote booster set-up. I think this would be ideal for me. Anyway, wanted to know if anyone has done this and how it turned out? Also, who are manufacturing remote power booster? I found a few but the were out of my price range. Could I find this type of set-up in the junk yard? thanks for your help.
Everything you know is wrong.
#42501 03/24/2003 6:32 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Here's another article for you. http://www.geocities.com/torkerscamaro/torker.html I believe they are called a Midland Booster....might try an internet search or a local parts house. Joe
Joe
#42502 04/12/2003 5:13 PM | Joined: Apr 2003 Posts: 5 Member | | Member Joined: Apr 2003 Posts: 5 | I had a similar setup on my wife's 55 2nd series. It used the original master and had the booster downstream mounted outside the frame rails. The power boost worked quite well but it still had a single master cylinder so I replaced it with a dual master/ booster combo from CPP Dan G | | |
#42503 04/12/2003 6:28 PM | Joined: Apr 2003 Posts: 5 Member | | Member Joined: Apr 2003 Posts: 5 | I had a similar setup on my wife's 55 2nd series. It used the original master and had the booster downstream mounted outside the frame rails. The power boost worked quite well but it still had a single master cylinder so I replaced it with a dual master/ booster combo from CPP Dan G | | |
#42504 04/15/2003 3:47 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | I have heard good reports about the Midland remote rv type booster, but it is a single system type. It uses a diaphragm like later trucks rather than a piston like the hydrovacs. There is a dual type remote booster carried by some of the street rod dealers. I've been very interested in this one myself.  | | |
