2 members (TexasFarmTruck, 1 invisible),
193
Mod | | | Forums66 Topics128,282 Posts1,058,497 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | i seen this truck on the net and i want to paint my 57 the same exact color were can i find out what color blue it is or a code were i can get it mixed lmk thanks [IMG] http://img.photobucket.com/albums/v175/oldno3fan/81911936_6.jpg[/IMG] | | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | fan - for starters, the forum owners prefer you make pics a link rather than inline, if you click the 'edit' button below the post you can change it
for the color, if it's near accurate, and a '57 color, it could be Alpine Blue [no known modern code], but every computer will show it differently, and of course the camera that took the picture left it's influence as well, so the "exact same color" could be any modern paint code - try printing the picture [printer will influence it some more] and take it to your paint supplier to compare with their sample chips .... or you could just go look at the chip books and take your pick
Bill | | | | | Joined: Jan 2008 Posts: 4 New Guy | | New Guy Joined: Jan 2008 Posts: 4 | The best bet would be to use the chromavision or aquire rx cameras that dupont offers but since you don't have that truck to scan, I would take the picture and look in a master chip book. It is easier this way because instead of being listed by car, code, and year. These chips are based on color ranges. We have two different masterchip books, one for solid colors and one for metallics and pearls. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | dawn I'd say, the alpine there looks a bit dark
Bill | | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | these trucks had beige interiors with black trim right ... geezz its had to find factory pictures of all stock trucks.. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no actual black - every 55-57 I've seen has had light gray interiors, with a mat finish 'charcoal' top of the dash [dark gray] and a similar gloss dark gray for steering column and floor - like this original, and this GMC .... the 58-59 interiors were different, and the ones I've seen are like this low mileage original 59Bill | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I don't have a '57. My '58 has paint code 710A, which I think is called Tartan Blue.
I'm not sure if you like the color, or are going for 1000% original. My color is close.
That said, I'm not even sure that my color is, in fact, an accurate representation of 710A, Tartan Blue, or some other version of blue a some paint manufacturer. I don't think you can ever get exactly to an original color, just close. It wouldn't surprise me one bit if colors shifted somewhat throughout the model year, depending on the supplier's ability to fill orders with repeatable results.
Cool 'bolt! And that truck's hubcaps are EXACTLY what I'm wanting. Wish non-chrome caps were available.
| | | | | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | Our '59 was originally Dawn Blue and the interior was the slightly metallic beige. The picture on your post looks very much like the original paint. (I found some protected spots of original paint when I removed a front fender.My brother repainted the truck Baltic Blue) The AD series "champane" interior color seems very close.(I also have some original paint left under the dash and behind the vent covers). My dad bought the truck new and it was built in the LA plant. John Atherton
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
| | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | correct i bought a touch up bottle and dawn blue looks to be correct color.... now i need to find correct interior color im really suppized theres not a fact book of some sort that shows color pictures of all originals .. also anybody know about the heater fan switch was it mounted in the panel beside the glove box my truck doesnt have the deluxe heayer thanks | | | | | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes on the heater switch, whatever level heater they came with the fan switch was there, the standard and dealer installed ones had a rotary sw mounted in the center of that panel
Bill | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I agree. I am painting mine Tartan Turquoise and depending on what kind of light you photograph it in, can look like THIS or THIS . The first picture is under a 60 watt light bulb and the second is the same parts under a florescent light. Out in the sun it probably looks a lot like the truck in your picture. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | |
