4 members (baldeagle, 2-Ton, Gazz, KDrown), 98 guests, and 3 robots.
Topics128,097
Posts1,056,495
Members48,444
#424873 06/19/2008 10:45 PM
I have 64 what is the cheapest way to convert to 5 lug.
The cheapest way to change the fronts is with a spindle swap; you can buy aftermarket spindles - that's the best way - or get used ones, but if you get used ones you will have to remove all the shims and you won't be able to get the caster right because the angles are different due to the lower control arms being closer inboard on the later model truck. The cheapest way to change the rears is to change out axles, but good luck finding someone to sell just axles.
What I did was to find a junk '75 1/2 ton and changed out the crossmember and rearend; you have to do a little work, but it all fits good.
Mike from Alabama
My truck on Stovebolt
My website
Why do we drive on a parkway, and park on a driveway?
Bkndsdl #424886 06/19/2008 11:34 PM
There are many ways to convert to 5 bolt wheels.I have no idea what is the actual best way. On my 55 2nd series I went with an aftermarket M2 frontend,TCI. I retained my stock rearend and had the axles plugged and redrilled at Moser Engineering in Indiana,they have a web site.Course you could go to a late model rear with a 5 bolt wheel pattern,
dale937 #424901 06/20/2008 12:20 AM
Unlees you want to lower it, the aftermarket spindles are not needed. Find yourself a '73-'87 C10 and use the spindles from them. You'll have to change over the balljoints to the ones for the later truck (no big deal, they'll fit your existing control arms) and I beleive that you may have to use the outer tie rod ends as well. I'd suggest searching the site to be sure about that. While thare will be a slight increase in track width in the front, any competant alignment man should be able to get the caster/camber/toe correct.
For the rear, you can have axleshafts from the later diff shortened and re-grooved for the C-clip. You will need to change out the spider gears to the later 30 spline, as yours will be the old 17 spline. Might be better to swap the whole differential if you can get one reasonable.
Bill Burmeister
