6 members (Peggy M, J Lucas, 78buckshot, Uncles51, Youngin' Tut 59, 1 invisible), 84 guests, and 4 robots.
Topics128,174
Posts1,057,048
Members48,458
#42478 02/14/2005 8:47 PM
As much as they have their good points I do want to rid my 49 of the torque tube. I have access to a 55 Chev truck rear axle. Would this be a good choice or is there something better and easier to install? I know i'll need to change the trans.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#42479 02/14/2005 8:50 PM
I have found the '55 truck rear a good working choice , but I did not change the trans ,, just modified the rear yoke and seal area to fit the open driveshaft.
I find the wee 216 responded well to the 3.9 diff ratio.
#42480 02/14/2005 9:32 PM
I think it's a good choice. In fact, you don't need to change the entire housing. The center section will bolt right in. Just get some after market perches and weld them on. I have this set-up on my 1946 1/2 ton with a 283 and a th350 and it works great.
Rick
smile
#42481 02/14/2005 10:47 PM
Dusty - you say you modified the rear of the trans to accept the open drive line. May have heard that before but could you give me some details please.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#42482 02/15/2005 9:54 AM
Grab a big yoke from an old truck that fits on the splines on the g/box tail shaft.
Make the speedo drive worm fit on to it.
Turn a slim housing to hold a seal that will bolt to the outside of the original tailshaft housing , the bit with the original 1/2 bell .
Source a seal to fit the yoke , turn the seal housing to match.
Make a new driveshaft to the right length .
What else have I forgotten ...........
Oh yeah ,, a slip joint at the front end of the new drive shaft.
I think thats about it ,, you'll get the gist of it once you get into the job grin grin
#42483 02/15/2005 7:15 PM
Sounds interesting - thanks for the idea!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
