0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | I'm trying to convert from 1-wire to 3-wire, have wired it based on info (it's all consistent (yes, I also used Mad Elecrtical site/info)) I got off the Internet, but the idiot light won't come turn off once engine is turned on. The #1 alt. spade is connected to the light, which is inline with ign. accessory switch. And the #2 alt. spade is connected to battery connection/bolt on back of the alternator.
Basically, the idiot light is on when ignition is switched on, but doesn't go out once the engine is started. I think it's still operating as a 1-wire alternator. I have to rev the engine to excite the alternator. Frustrating.
Any suggestions would be greatly appreciated.
Regards. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Starsfan,
Did you buy a new 3 wire alternator, or did you have a new regulator put in your old single wire unit.
You have it wired properly and your guess about still acting like a single wire sounds accurate.
I won't ask you why you did this change, but I'll bet it's the regulator.
Stuart | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Idiot lights will stay on until the alternator is excited. That is why over the road trucks have volt meters these days. A volt meter gives you an indication of what your entire electrical system is doing. You can be charging but if you have too much draw you can actually be discharging the battery. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Starsfan,
A Delco regulator #DA-94SE is a self exciting (1 wire only) regulator. It has two tabs and looks exactly like a Delco D668 which is a 3 wire regulator.
It sure sounds like the DA-94SE isn't supplying ground to your charge light/key wire after the alternator is revved up and charging. Again, my guess is that #1 is a dummy terminal, either that or your wire from key to #1 isn't contiguous.
Stuart | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Are you shure the alt. you put on is good? Put a volt meter on & see if it is acualy charging or not. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | It is...I've had it a couple of years and it charges the battery fine. I've tested it before (many times in the past) and it's always fine. Thanks. | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | You indicated that the #2 connector is wired to the battery connector terminal. Try removing that wire and running the wire from the #2 connector to the ignition switch - ign on. It should solve your problem. Fred
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Fred,
Share your secret. How would this work.
Stuart | | | | | Joined: May 2008 Posts: 2 New Guy | | New Guy Joined: May 2008 Posts: 2 | Greetings, I just repalced a generator with a 3 wire alternator (7127). I would like to verify the reference to no.1 and no.2 positions and relationship to the "R" and "F" marking on the back of the alternator. I thought I had it set up correctly, but found my battery had drained this morning. Thanks Ralpho.
PS: I will keep reading incase you already covered this topic in other postings. Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Ralpho,
From another Northern Californian, welcome to the Stovebolt. SI alternators were usually marked with 1 and 2, but can be marked with the letters R and F as well.
#1 corresponds to R and #2 corresponds to F. 1 on the alternator is the switched (key) wire that initially excites the alternator and #2 ties into the system wiring to monitor and adjust the internal regulator.
A failed diode inside the alternator will allow the battery to discharge while the rig is parked. It might be worth having a shop test your alternator. Good luck.
Stuart | | | | | Joined: May 2008 Posts: 2 New Guy | | New Guy Joined: May 2008 Posts: 2 | Stuart, Thank you for the response. First of all my truck is a 1956 6400 dump. Since the alternator was too expensive to replace I thought I would make the effort and convert to an alternator. I first had the #2 wire connected to the horn relay number #3 tab. That is what I think caused the battery to drain. I then switched the wire to the ballast resister since it should only be hot when the key is in the "on" position. Things seemed to check out ok with that change. For some reason my wires started to fry when I left the key in the "on" position for a long period of time. Thank goodness someone noticed smoke coming from under the hood. Just to be clear can you tell me where I should connect the #1 and #2 wires? Thanks Ralpho | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Ralpho, It's fine to wrap the #2 wire around and connect it to the large BATT terminal on the alternator itself. #1 needs to see a key switched voltage. The coil + is a standard connection point, but sometimes this results in engine run-on after the key is turned off. That #1 wire will actually power the ignition after the alternator starts to charge, hence the inability to shut the engine off. They make a little pigtail for the DA plug that includes a diode in series with #1 wire to prevent the run-on. I don't know if a '56 had a charge indicator light (GEN light) on the dash or not. If it did, this would have been connected to voltage regulator terminal #4. This would be a place to connect alternator #1. I might be confusing you...or myself. I have enclosed a link that might show it more clear. Take a look and holler if things still look bleak. http://www.hotrod.com/techarticles/marlan_davis_technical_advise/photo_22.htmlStuart | | |
