2 members (baldeagle, 78buckshot), 20 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#42454 07/17/2003 7:14 PM
Junior Member
Junior Member
I been looking around on the web, and I'm curious about performance parts for inlines. My truck has a 57 235, and I was wondering how much difference it would make to add a 2 or 4 bbl and headers. What kind of difference in horsepower/torque, gas mileage, and highway speed would this make? If this would make significant improvement it would cost considerably less than rebuilding my 283.
GrannyLow
#42455 07/17/2003 10:10 PM
It will help everything but your hiway speed. You need a gear change for that.
54 3100 with 235
62 flatbed dump C60 with 261
#42456 07/18/2003 1:06 AM
knuckle head
knuckle head
On a good 235, with a hotter cam, headers and improved fuel delivery,160 HP is the figure most commonly mentioned.These modification would cost almost a $1000, new parts price, if you did the labor yourself.That makes the 200 hp 283 not so expensive in comparison.
#42457 07/18/2003 4:35 AM
Junior Member
Junior Member
Since I am problaby going to have to rebuild my 283 and put it in my truck eventually, does any body know what you need to do to make a 302 "stroker" out of a 283?
GrannyLow
#42458 07/18/2003 4:59 AM
can ya do that? I thought 302 was 283 stroke 327 bore - think you got a 283 block that'll take 4" bore? hasta be 59-62 w/o badly corroded water jacket
#42459 07/18/2003 2:08 PM
If you put a small-journal 327 crank in a 283 block with the right pistons and rods, you'll get the 307. Pretty decent motor, but don't know much about their performance.
You have to put a 283 crank in a '62-67 small-journal 327 block to get the famous DZ302.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#42460 07/18/2003 5:28 PM
Junior Member
Junior Member
Ok, I see, It seems I got a little confused around midnight :confused: , But thanks anyway guys.
#42461 07/19/2003 12:16 AM
Quote
According to "How to Rebuild You Small Block Chevy" (and my personal experience, I did this once) the earlier 283s could be bored to 4.00 and you'd have a very nice 302. This was the original 5.0 liter race motor used in some late 60s race apps. If you've got a 58 to 62 or so 283, you can bore it. 57s and also post 62s were thinner-walled and don't all take a bore job well.
The 327 is a stroked and bored, 4 x 3.25, motor. A 327 crank yields 305 or 307 or thereabouts, in a 283 bore.
If you can bore to 4, do it, it's cheap enough. Probably needs a bore job anyway. Otherwise I'd run it stock, skip the hassle.
Good luck!
George
#42462 07/19/2003 7:38 AM
Junior Member
Junior Member
I'd stick with the 235 you have and add some goodies...I've been to a few big old car shows, and have seen VERY FEW old trucks or cars with straight-6's, even though that's what they used to have. They all have V-8's (mis)placed in them. wink I like seeing a nicely redone inliner with a bunch of performance parts, especially since they seem to be pretty scarce. Plus, it's always fun to be different! cool
Carl
...Oh, and did I mention you will save yourself a TON of time and/or money by sticking with the engine that already fits in your truck without modification of anything? That would play a big part for me.
