| | | Forums66 Topics128,108 Posts1,056,238 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | I can't believe there aren't more posts on this subject. I'd like to start one on a good, durable paint scheme, other than powder coating, that guys have had success with on their wheels. Epoxy? Heavy equipment paint? Regular body paint and primer? Let's hear it...
Dave
| | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | Here's my experiment . . . so far Wheel Restoration Don't know when I'm gonna get back to it. Will probably be some small changes to this page when I do. | | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thanks for the info, LAROKE. I think I'll give the epoxy primer and topcoat route a try.
Dave
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Blasted then PPG DP90LF epoxy primer and Delstar (DAR) top coat. Don't see how the factory job that lasted half a century could have been any better than that. Easy to touch up also it the need arises. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2008 Posts: 10 New Guy | | New Guy Joined: May 2008 Posts: 10 | I used Bill Hirsch Miracle Black. This is essentially the same as POR-15 or KBS-coatings. It turned out very well and is much more hardy than regular coatings. I just stripped the old paint, cleaned, and brush painted. | | |
