0 members (),
53
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42432 05/17/2005 1:41 PM | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Okay my water outlet cover was leaking antifreeze on my 283. I pulled the hose and drained some antifreeze then proceeded to pull the cover and the old gasket fell apart. I wipe the area off and put the new gasket on and tested. She leaked like a sieve.
So I bought a new water outlet cover, new gasket and some silicone gasket material. layed a bead on both sides of the gasket and secured the water outlet cover.
I will be testing this set up this afternoon but in theory it shouldn't leak, is that a correct theory? If it does leak what do I do next.
Thanks, Chris
Chris 1955FirstSeries
#42433 05/17/2005 9:05 PM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Yeah, that should work fine. I usually always coat both sides of a water gasket with silicone.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
