0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#42432 05/17/2005 1:41 PM
Okay my water outlet cover was leaking antifreeze on my 283. I pulled the hose and drained some antifreeze then proceeded to pull the cover and the old gasket fell apart. I wipe the area off and put the new gasket on and tested. She leaked like a sieve.
So I bought a new water outlet cover, new gasket and some silicone gasket material. layed a bead on both sides of the gasket and secured the water outlet cover.
I will be testing this set up this afternoon but in theory it shouldn't leak, is that a correct theory?
If it does leak what do I do next.
Chris
Chris 1955FirstSeries
#42433 05/17/2005 9:05 PM
Yeah, that should work fine. I usually always coat both sides of a water gasket with silicone.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
