5 members (Wayne67vert, Gray_Ghost, tclederman, Ridgeback, 1 invisible), 56 guests, and 5 robots.
Topics128,021
Posts1,055,372
Members48,420
#42430 11/20/2004 5:47 AM
Hey Guys,
Today I replaced the original 1962 waterpump on the 235, and when I had the belt off, I decided to check the harmonic balancer. The pulley is loose on the balancer. eek frown One side is tight, and the otherside is loose. After I had put everything back together, I can still hear the "clackity clack". :mad: Which I thought was the waterpump, that's why I replaced it. frown
It looks like the pulley is riveted to the balancer? :confused:
I heard that the balancer has to be heated up before sliding it on the end of the crank? :confused:
How do you take off, and reinstall a harmonic balancer on a 1962 235 I6? I have replaced harmonic balancers before in the past, but not a 235. :o
TIA,
David
My truck don't leak oil, it just marks its teritory.
#42431 11/20/2004 2:43 PM
Y
Y Offline
Chevyboy, I used a standard puller to remove the stock balancer from my 235 in the '61. Was no big deal. I replaced it with a balancer from a later 250. Took both balancers to a machine shop where they measured and cut the snout off the old balancer to make a spacer for the newer one. This gave me the extra pulley positions I'll need to run the PS pump and AC compressor. I put it back on by using light taps from a hammer cushioned by a one foot length of 2X4. Just tap it on until the snout bottoms out against the timing gear inside. I did drill and tap the end of the crank while I was at it as well. Extra insurance against it coming off in the future. There are plenty of different opinions on the re-install issue expressed in other posts here. HTH
