0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
Apprentice
Apprentice
my 1966 GM c50
Looks like its a single resevouir, pretty small cap with a single bolt holding it down.
Is this also a single piston setup? If so do I have any options on a master cylinder replacement with dual piston and would there be an option with vacuum assist?
3B Offline
Hy Rambos Ride, yes that should be a single system master, [rectangular cap], as to the booster, that is usually mounted after the master cylinder on that vintage of truck. They're called remote boosters, Hydrovac is one name for them. I personally would not bother to install a dual master cylinder, a properly setup single system will work [and have] for many years, hope that helps.
Apprentice
Apprentice
Thanks - are the master cylinders available rebuilt or at least a kit? Too late to call NAPA tonight!
3B Offline
Hy Rambos Ride, the Napa part number for that master cylinder is UP34403 $77.49, that is the cheapest master cylinder I have seen in a long time, hope that helps.
