8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible),
181
Mod | | | Forums66 Topics128,086 Posts1,056,094 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 37 Apprentice | | Apprentice Joined: Jun 2008 Posts: 37 | my 1966 GM c50
Looks like its a single resevouir, pretty small cap with a single bolt holding it down.
Is this also a single piston setup? If so do I have any options on a master cylinder replacement with dual piston and would there be an option with vacuum assist?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Rambos Ride, yes that should be a single system master, [rectangular cap], as to the booster, that is usually mounted after the master cylinder on that vintage of truck. They're called remote boosters, Hydrovac is one name for them. I personally would not bother to install a dual master cylinder, a properly setup single system will work [and have] for many years, hope that helps. | | | | | Joined: Jun 2008 Posts: 37 Apprentice | | Apprentice Joined: Jun 2008 Posts: 37 | Hy Rambos Ride, yes that should be a single system master, [rectangular cap], as to the booster, that is usually mounted after the master cylinder on that vintage of truck. They're called remote boosters, Hydrovac is one name for them. I personally would not bother to install a dual master cylinder, a properly setup single system will work [and have] for many years, hope that helps. Thanks - are the master cylinders available rebuilt or at least a kit? Too late to call NAPA tonight! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Rambos Ride, the Napa part number for that master cylinder is UP34403 $77.49, that is the cheapest master cylinder I have seen in a long time, hope that helps. | | |
