6 members (J Lucas, Peggy M, Stovebolt48, papas52, 2 invisible), 118 guests, and 3 robots.
Topics128,193
Posts1,057,253
Members48,466
Apprentice
Apprentice
Is there enough room to replace the manifold gasket without completely removing the manifolds from the engine compartment. I was thinking that if I could get the manifold off the head studs on each end that I could remove the old gasket and replace the new one by just letting the manifold (with carb off) "rest" on the exhaust system and avoid pulling the whole thing out. Anybody tried this??? My engine is stock 216 in a 47 1/2 ton Chevy.
mazzer,
I think you can do it that way. If the header pipe is strong enough to support the whole assembly, yet flexible enough to allow you to swing it back out of the way a bit, then you have it made.
Keep in mind the difference in doing it that way and removing it completely is only two bolts! Taking it all the way off would allow you to easily clean up the gasket surfaces....real important.
Don't forget there are three alignment rings that the new gasket will have to be slipped over. If I remember correctly, that intake/exhaust gasket isn't one piece either.
I think very little is to be gained by leaving it dangling to do this chore....but then again, I'm not the one doing it!
Stuart
