5 members (porsche, Bill Hanlon, Steelonsteel, ‘37ChevyPU, carbking), 99 guests, and 1 robot.
Topics128,051
Posts1,055,767
#423341 06/15/2008 3:14 AM
Found another problem
The truck came with a drive shaft yoke with a 26 splines.
The trans has 16 splines
when chev stop using the 16 spline and switch to the 26 spline on the yoke and tailpiece?
I might have to have a drive shaft built
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
you can find a coarse yoke to fit the trans [change it yourself, doesn't have to be "built"] or you can find a later all-syncro trans to suit the driveshaft, bolts right in
the trans you'd need would be 68 up truck 3 speed, I've used them in all my trucks and prefer'em - probably that's the year the standard spline count changed
