2 members (Otto Skorzeny, 1 invisible),
107
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | I bought 5 chevrolet moon hub caps and soon found out that 2 of the wheels did not have clips to attach the moons. I purchased some and for the life of me can't get the moons to catch on to the clips. Can some one who has done this project give some advice? | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I think just about everyone goes through this because there must be a hundred different wheels that fit these trucks but only a couple have the correct clips.
Try measuring the ones that work and compare them to the ones that don't. Chances are you clips are too far recessed. I sidestepped the whole issue when I put disk brakes on mine and put a set of Smoothies from Wheelsmith on mine. They sell hubcaps that match the stock design.
Good luck. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | see daves tips on hub-caps... i'll bet you could make it work w/ a little helpin' know how........ http://www.speedprint.com/deves50/hubcapclips.phpi had to space my clips higher so my dishes would fit. i think i used #10 or #12 machine screws (by x length) to do mine and a 1/4''i.d. (or smaller) steel pipe as the spacer.  extra clips are about $1.25 ea. at any of the AD supply catalogues. i bought 24.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
