5 members (carbking, Bill Hanlon, Hanks custodian, Chris's 46 / 515, Gdads51), 186 guests, and 1 robot.
Topics128,197
Posts1,057,258
Members48,466
TPB
Offline
I bought 5 chevrolet moon hub caps and soon found out that 2 of the wheels did not have clips to attach the moons. I purchased some and for the life of me can't get the moons to catch on to the clips. Can some one who has done this project give some advice?
I think just about everyone goes through this because there must be a hundred different wheels that fit these trucks but only a couple have the correct clips.
Try measuring the ones that work and compare them to the ones that don't. Chances are you clips are too far recessed. I sidestepped the whole issue when I put disk brakes on mine and put a set of Smoothies from Wheelsmith on mine. They sell hubcaps that match the stock design.
Good luck.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
see daves tips on hub-caps... i'll bet you could make it work w/ a little helpin' know how........
http://www.speedprint.com/deves50/hubcapclips.php
i had to space my clips higher so my dishes would fit. i think i used #10 or #12 machine screws (by x length) to do mine and a 1/4''i.d. (or smaller) steel pipe as the spacer. wink extra clips are about $1.25 ea. at any of the AD supply catalogues. i bought 24.
Jim & Caroline
